I did not find an online parts listing for a diesel 350 so I have no way of checking what parts were used.
If the fuel return line goes to the bottom of the tank most likely there was a check valve originally installed to prevent fuel from returning to the pump. Often these check valve caused problems and the ball and spring removed. If that is the case with your tractor you may have to remove the return line from the pump and either plug it or raise it above the fuel level in the tank.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
