Re: 560 Hydraulics cant hold implement up
Posted by heyiou on March 22, 2011 at 14:10:47 from (69.29.44.91):
In Reply to: Re: 560 Hydraulics cant hold implement up posted by Janicholson on March 21, 2011 at 16:05:04:
Ok, I've checked the valve and it was in the correct position. So what actually keeps the fluid from going backwards? the relief valve/pressure control block? or the double acting valve? I'll probably have to tear them both apart to find the issue, but at least I'm getting it narrowed down. Could low fluid have anything to do with this? haven't checked it, but curious. I wouldn't think so. The hydraulics seem strong when moving the 3pt up and down, they just dont stay up.
