Valves and control. If the pump were bad it would not raise, and that is not an issue. Be sure the control switches on the Valves (I think) are set to double acting. If any one is part way, or wrong it can be directly responsible. On the end of the valve will be a turn knob with a roll pin and sheet metal clip. Check it. Best of my memory. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
