Re: SA front main seal
Posted by Janicholson on March 22, 2011 at 20:31:19 from (67.72.98.45):
In Reply to: SA front main seal posted by mikeinwa on March 22, 2011 at 19:54:03:
Try more and different words in the search.
Pulley installation, A pulley removal, C pulley removal, Front pulley puller.
There are many posts.
The pulley must be forced off with a puller that contacts the entire back side of the pulley (bearing splitter works well) the puller is often made with 5/8 all thread and a hydraulic jack or porta power for force. Warming the pulley helps, but just with propane, not Oxy-acetylene. Putting it on can use threaded rod into the cover main bolts and pushing straight with a socket or bearing pushing puck to make circular contact.
Modest polishing of the snout and pulley are appropriate (do not make it loose) Make sure the new seal has a clean place to seal, and not in a grove from the old seal. Do not heat it to put it on, it could ruin the seal. Speedy sleeve and seal is a solution for grooved shank. Good luck.
Jim
