Posted by El Toro on March 23, 2011 at 06:40:37 from (108.3.156.106):
In Reply to: H still wont start posted by pintobill on March 22, 2011 at 17:02:50:
Has the engine ever run? Check the easy things your plug wires should be in this firing order on the distributor cap. Hal
2-1 4-3 As the rotor rotaes CW.
If this is connected right remove No1 sparkplug near the radiator and bring that piston to TDC on the compression stroke. Hold your thumb over the plug hole while a helper hand cranks the engine until you feel pressure against your thumb.
Once you feel pressure drop a plastic straw on top of the piston and watch the straw rise as the engine is slowly cranked. When the straw quits rising you should be at TDC on the compression stroke. Then remove the distributor cap and see where the rotor is pointing. You need to provide more info as to whether you have fire to your plugs, getting gas to the carburetor. Saying it won't start isn't much help. Hal
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
