Re: H still wont start
Posted by sflem849 on March 23, 2011 at 07:29:44 from (69.197.84.192):
In Reply to: H still wont start posted by El Toro on March 23, 2011 at 06:40:37:
El Toro said: (quoted from post at 06:40:37 03/23/11) Has the engine ever run? Check the easy things
your plug wires should be in this firing order on the distributor cap. Hal
2-1
4-3 As the rotor rotaes CW.
If this is connected right remove No1 sparkplug near the radiator and bring that piston to TDC on the compression stroke. Hold your thumb over the plug hole while a helper hand cranks the engine until you feel pressure against your thumb.
Once you feel pressure drop a plastic straw on top of the piston and watch the straw rise as the engine is slowly cranked. When the straw quits rising you should be at TDC on the compression stroke. Then remove the distributor cap and see where the rotor is pointing. You need to provide more info as to whether you have fire to your plugs, getting gas to the carburetor. Saying it won't start isn't much help. Hal
He had an earlier thread where he went over a bunch of that stuff.
It's all good. You can't watch them all. This would be a great time to rant about how if everybody used the new forum there would be no need for people to start a new thread just to get noticed. All you would have to do is post and it would go straight to the top no matter how many years old it was...but I will only rant that much :lol:
Here's the link to the other thread
http://ytforums.ytmag.com/viewtopic.php?t=751417
This post was edited by sflem849 at 07:41:07 03/23/11.
