Re: Do I need a ballast resistor??
Posted by Corky on July 22, 2000 at 05:27:38 from (63.22.8.110):
In Reply to: Do I need a ballast resistor?? posted by Brian Schoenberg on July 21, 2000 at 14:11:46:
Brian sence you allready installed a 12v coil you don't need the resistor.It is used only if you keep the stock 6v coil. Good luck
Post A Followup
: Re: Re: Do I need a ballast resistor??
