Re: Re: Do I need a ballast resistor??
Posted by ltf in nc on July 22, 2000 at 07:45:51 from (206.228.214.100):
In Reply to: Re: Do I need a ballast resistor?? posted by Corky on July 22, 2000 at 05:27:38:
A ballast resistor is required. It can be either internal or external. Without such a resistor the coil will overheat and the point life shortened. A load resistor is used when a 6 volt coil is retained, when converting to 12 volts, to limit the voltage to six.
Post A Followup
: Re: Re: Re: Do I need a ballast resistor??
