Re: Replace alternator belt on 300
Posted by d beatty on March 26, 2011 at 11:47:21 from (71.239.246.137):
In Reply to: Replace alternator belt on 300 posted by zlarryd on March 26, 2011 at 10:31:13:
You can get the belts over the fan with a little work. You have to first loosen the set screw on fan pulley and then loosen the flange on the front side of pulley.Than slip the water pump belt over the loosened flange. You should than be able to slip other belt over fan and under the water pump belt and than replace the water pump belt.
