Re: Wore Out Front Cultivator Supports On Super A
Posted by Jim in Ma. on March 27, 2011 at 08:13:29 from (72.74.2.162):
In Reply to: Wore Out Front Cultivator Supports On Super A posted by eddiebuck on March 26, 2011 at 22:24:30:
Have you looked at the pins in the joints?
Could you add shims or bushings to tighten them up?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
