Re: Wore Out Front Cultivator Supports On Super A
Posted by eddiebuck on March 27, 2011 at 13:53:55 from (71.49.34.16):
In Reply to: Re: Wore Out Front Cultivator Supports On Super A posted by Jim in Ma. on March 27, 2011 at 08:13:29:
Thats what I have in mind.Shims,bushings or new bolts I think would fix the problem.Just wanted to know if anyone else had used them and the outcome. Thanks everyone. eb
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
