Can I use a used piston on 400?
Posted by bugspot on March 27, 2011 at 15:08:15 from (75.97.216.79):
I'm having no luck on the 400s I'm buying. My "55" needs a head gasket. I found #1 piston is deteriorated on top at the low side of the step. It's low enough to see compr. ring. All other pistons look good. I don't know if I should use it. Is it ok to take a piston out of "54" and install it to replace bad piston? Do I just need to crosshatch cylinder and install new rings? Harvick just made an awesome move to Win! Thanks Tim
