Re: Can I use a used piston on 400?
Posted by mkirsch on March 29, 2011 at 05:32:16 from (64.80.110.74):
In Reply to: Can I use a used piston on 400? posted by bugspot on March 27, 2011 at 15:08:15:
"Just do an overhaul."
That's fine and dandy if you're made of money. Just the overhaul kit is $726.71 on this website. Plus machine work on the head. Plus machine work on the crank. Plus machine work on the block if the deck is warped. Plus any tools you have to buy or rent.
By the time all is said and done, you're looking at $1500-$2000, and that's if you do most of the work yourself.
For what? So the tractor can sit out in the weather, pull a wood trailer, push some snow, maybe plow a garden, and take the grandkids for a ride once in a while?
You don't need a fresh engine for that.
As long as the used piston is the same as the other three, and nothing is rattling around when you put it together, you can't make things any worse than they already are. It's worth a try.
