D282 cracked sleeve pic
Posted by robgIN on March 28, 2011 at 14:47:42 from (76.208.31.233):
third party image
I have read posts here about engines running fine good oil pressure then knocking badly and finding a pan full of chunks of metal that used to be a sleeve before the got pulled down into crankcase and destroyed by the crank. This is a before pic luckily. We tore it down for a valve issue and saw this. Would have been a lot worse pretty soon.
