Re: cub tranny bearing question [ rephrased]
Posted by ericlb on March 31, 2011 at 06:30:52 from (70.41.96.39):
In Reply to: cub tranny bearing question posted by ericlb on March 31, 2011 at 05:44:04:
i didnt write the writin right, what i meant to say was to change the bearing, can i remove the large differential cover on the rear of the tractor along with the pto, and top of the tranny and change the bearing, or do i split the tractor, and if so, do i split at the tranny and torque tube,and roll or carry it to the rear, or do i have to split it at the bellhousing? maybe this will make more sence
