You will have to split the tractor and remove the clutch shaft which is also the top transmission shaft. You may expect to find the roller bearing rides on the shaft and the shaft may need to be replaced. Aftermarket shafts are readily available. You don't need to disassemble the rear end. The work can be done by splitting the tractor between the transmission and clutch housing. You may need a second hand to help guide the shaft into the clutch during reassembly. Never force it together. When things are lined up, they will fall together. K-Mo
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
