Re: primer
Posted by Guy Fay on July 24, 2000 at 05:37:56 from (169.207.194.245):
In Reply to: primer posted by gene on July 23, 2000 at 17:29:07:
According to the engineers I talked to, they really didn't use a primer before 1965 on the whole tractor. On engine blocks, transmission casings, and other parts that held oil, they used a whitish sealer if oil was leaking through a pourus section of the cast iron. Sometimes they had a bad day, and entire blocks and casings would be white.
Some individual parts would also be painted by the outside factory, like generators and starters.
Post A Followup
: Re: Re: primer
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
