International 404 transmission fluid leak
Posted by Byron F. Stone on April 01, 2011 at 20:16:42 from (98.84.138.63):
I have been loosing fluid at a high rate & have been at a loss.I have looked all under the tractor looking for a source & I am still not sure.
Dose the PTO shaft get it's lubrication from the same sump as the transmission & 3 point hitch?
If it turns out to be the source of the leak,what will be the fix?
Byron
