When you say you can't find the source of the leak, do you mean there is a puddle under the tractor, but you don't see where it comes from? Or is the fluid disappearing and you don't know where it is going?
If there is no fluid on the ground, check the crankcase. The 404 uses a hydraulic pump to circulate the transmission fluid, and the pump seal can fail and let the fluid into the crankcase.
If there is a puddle, clean the bottom of the tractor really well, let it sit and run, and you should be able to see where it leaks from.
I believe the PTO is separate from the transmission, everything else works from a common reservoir.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
