Posted by LaBoyteaux on April 02, 2011 at 08:31:16 from (76.14.94.14):
In Reply to: Spun Bearing? posted by pete_5959 on April 02, 2011 at 08:08:01:
I tried to go back to your earlier post to understand the problem. Have you tried holding the carburator in the idle position and restarting the engine. If engine started racing and governor was OK I'm wondering if there is some problem in the governor-carburator linkage or throttle valve in the carburator. If oil pressure is normal probably no spun bearing.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
