Spun Bearing?
Posted by pete_5959 on April 02, 2011 at 08:08:01 from (24.74.222.222):
I posted a few weeks ago on a H engine problem caused by an unknown increase in rpm while idling. I have checked the governor and all is as it should be. I have pulled the valve cover and oil pan. Nothing broken. Closed valves on each cylinder and pressure checked all ok so no valves through pistons. Can I assume I have a spun bearing and any advice on a way forward is appreciated.
