Re: Farmall h starting problem
Posted by Janicholson on April 02, 2011 at 16:46:25 from (67.72.98.46):
In Reply to: Farmall h starting problem posted by farmallboy15 on April 02, 2011 at 16:01:33:
If the lights work, Turn them on, put something in front of them so you can see their brightness, then hit the starter. If they dim way down the starter is jammed in the flywheel. Put it in high gear and rock the rear tires forward and back violently. Watch the fan if it moves, it is unstuck. If it does not, loosen the starter bolts and wiggle the starter till it clicks. That will make it work (for a while) It needs a new style starter drive, with no big spring on it.
If the lights do not turn on, or go all the way out instantly, the battery cables are loose on the battery, or where grounded, or where attached to the Starter Switch, or starter. (several styles of switch are used, so I can"t point to it) Jim
