Farmall h starting problem
Posted by farmallboy15 on April 02, 2011 at 16:01:33 from (67.54.192.38):
I have a 1950 H. it was running great and starting perfectly until last week when it started running rough. Pulled the spark plugs and they were pretty well fouled and covered in carbon. so today i replaced the spark plugs and put in a tune up kit while i was at. At first i had done the point adjustment wrong and the tractor turned over great but would not start and i realized my mistake. so i fixed the point adjustment. but now when i hit the starter button there is nothing? not even a click that the starter is engaging. Any ideas??? this is a 12 volt battery with a distributor. any help is appreciated!
