Check to see if the motor will turn over. If you have some bad spots on your ring gear the starter drive can jam up against the ring gear and lock up everything. If that's the case just loosen up the starter enough to get the drive loose, move the motor a bit and reattach the starter. I've got 3 that does that at least once per year. I'm going to have to fix some ring gears one of these days. If this isn't the answer and your battery is good then its probably the starter button. They don't seem to last, especially if they sit out side.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
