Re: Farmall h starting problem
Posted by Brian Dan on April 02, 2011 at 17:41:33 from (24.179.177.168):
In Reply to: Farmall h starting problem posted by farmallboy15 on April 02, 2011 at 16:01:33:
First start at the battery, Check all connections then check ground. Then check switch.
Keep working toward the starter.
