Re: Spun Bearing?
Posted by Owen Aaland on April 02, 2011 at 21:58:25 from (216.47.32.52):
In Reply to: Spun Bearing? posted by pete_5959 on April 02, 2011 at 08:08:01:
Take a # 194 light bulb, straighten the contact leads, and solder a few feet of electrical wire to each one. Add an alligator clip to the other end of each wire. Attach the leads to a 12 volt battery. You will now have a light that will fit through the spark plug holes.
You should be able to see where the screw is imbedded in the piston. You should be able to pop it loose with a long screw driver and pull it out with a small magnet. If the screw is brass, put a dab of grease on the end of the screw driver and use that to get the screw out.
