Re: Re: Re: Water in Oil
Posted by The Red on July 24, 2000 at 15:49:07 from (12.75.197.146):
In Reply to: Re: Re: Water in Oil posted by Andy on July 24, 2000 at 14:42:39:
Andy my guess is that you have multiple problems. Oil wise, I am guessing that this engine had non-detergent oil for a Long time. You might be breaking up sludge with detergent oil. I would suggest you change the oil and the filter with 8 quarts of detergent SAE 30 and run it again and check the oil after an hour of running or so. You might want to drop the oil pan and give it and the oil inlet screen on the oil pump a good cleaning.
Cooling wise, if you have some minor leaks in the radiator, you will lose coolant pretty quick. I am not sure you have coolant getting into the oil at this point in time.
Post A Followup
: Re: Re: Re: Re: Water in Oil
