the coil shouldnt heat up that quick. do you have a test light? if so, disconnect the wire that goes from the distributor to the coil, hook one end of the test lite up to the distributor wire that came from the coil. touch the test lite probe to the power source on the tractor. if you open the points up, the lite should go out. it should glow when the points are closed. if it glows when the points are open, there is a short either at the point where the power wire goes thru the distributor housing, or inside the distributor, the connection at the condenser is shorting out.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
