Re: Farmall h starting problem again
Posted by farmallboy15 on April 03, 2011 at 08:01:52 from (12.213.80.54):
In Reply to: Re: Farmall h starting problem again posted by glennster on April 03, 2011 at 06:34:40:
ill try what you said glennster. also should the coil be heating up when the engine has only been cranked a little bit? could the coil be my problem?
