Re: can you replace a d282 main bearing without removing ...
Posted by teddy52food on April 04, 2011 at 17:16:57 from (68.169.216.43):
In Reply to: can you replace a d282 main bearing without removing crank? posted by NolanJae on April 04, 2011 at 13:20:07:
I use a copper rivet in the oil hole & turn the crank so the rivet contacts the side away from the tab. Install the other way.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
