can you replace a d282 main bearing without removing crank?
Posted by NolanJae on April 04, 2011 at 13:20:07 from (97.127.81.160):
I completed an in-frame overhaul on my 560 d282 and had to split the tractor to put in a rear main seal and a clutch job (have not put the seal in yet and flywheel is being machined). Can you replace the rear main bearing without removing the crank? If so what needs to be done? My IT book is a little light on info regarding this subject. Can a guy pull off the cap without removing the engine plate and spin those bearings out and in?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
