Re: can you replace a d282 main bearing without removing ...
Posted by pete 23 on April 04, 2011 at 18:37:01 from (74.44.100.190):
In Reply to: can you replace a d282 main bearing without removing crank? posted by NolanJae on April 04, 2011 at 13:20:07:
Sure you can put them in from the bottom. It is not the best way of course, but then not everything is done the best way. One does what one has to do at the time. I am not a plasti gauge guy but if you do use it to check clearance, you need to support the crank. Easiest way is to remove cap next in line and put a piece of carboard or for a shim and tighten cap down, this will hold crank up against top so you get a better reading with the plastigauge. I prefer to use different thickness of shim stock for checking clearances, about half inch wide and length of bearing and tighten cap down and check drag. More accurate. Of course, not all agree. On that rear cap you have to use alignment dowels(anything that fits the groove nice) and a little dab of sealer on parting line of cap to block. If you have groove in crank where seal rides you can leave seal out just a hair but not so far it touches flywheel. There is also a speedy sleeve available at some parts suppliers like HY-Cap.
Today's Featured Article - A Question for Dads This recent topic from the Tractor Talk discussion board is being highlighted because it is an awesome display of the caliber of individuals that have made this site their own. The young person asking questions received positive feedback and advice from total strangers who "told it like it is" with the care many reserve for their own kids. The advice is timeless... so although it isn't necessarily antique tractor related, it will be prominently displayed in our archives to honor those who have the courage to ask and those who have the courage to respond in an honest, positive manner. ... [Read Article]
