Farmall H Generator
Posted by Picklesmith on April 07, 2011 at 05:14:44 from (24.35.163.46):
I am reconditioning a 1951 Farmall H. The electrical system is the original 6 volt system with a positve ground. The tractor has a voltage regulator attached to the steering column. While the tractor is running, the ammeter shows a slight discharge reading. What voltage reading should I be getting at the generator terminals when the tractor is running? Appreciate your help. Thanks.
