Farmall Tractors Discussion Board
Re: Farmall H engine problem
Posted by mjdelaney on January 04, 1999 at 09:50:27:
In Reply to: Farmall H engine problem posted by WayneR on January 03, 1999 at 13:41:40:
I had similar problems. I assume the engine is tuned up and valves/compression are okay. Ended up replacing Intake/exhaust manifold, gasket, and studs. Do you have the combination Gasoline/ Kerosene manifold set up? In my case I converted to straight gas.
I had trouble with Champion plugs too. I wondered if they changed the heat range but not the number. Shifted to AC a hotter plug and that solved my problems.
This is an aggrevating problem, but you will be well rewarded for your efforts.
Post a Followup
: Re: Re: Farmall H engine problem
