f-12 antifreeze in oil
Posted by WACP on April 07, 2011 at 07:07:43 from (75.11.153.98):
Went out to change the oil in my f12 yesterday,the oil has not been changed in about 9 months, does'nt get ran a whole lot. When I drained the oil it had some antifreeze in the oil,not much at all I would say less than 3 to 4 tablespoons came out first. Tractor does'nt smoke at all and none of the cylinders seem to have any antifreeze in them,I do have a small leak of oil and antifreeze in the front of the engine seems to be coming from the pully at the bottom. Could this be a head gasket or more likely a cracked block. Last i was wondering since this leak seems to be so minor at what point should i dig into the engine to check it out,is it safe to run the engine with a little antifreeze leaking in the oil. All I do is show the tractor and use it for hay rides.
Thanks for any help
