Re: f-12 antifreeze in oil
Posted by Bill in NJ on April 07, 2011 at 09:59:28 from (4.248.92.55):
In Reply to: f-12 antifreeze in oil posted by WACP on April 07, 2011 at 07:07:43:
Anti-freeze in the oil is not a good thing. It can only come from a few places. Most common, cracked head, cracked block, cracked sleeve(s), bad head gasket. The problem is if there is too much anti-freeze in the oil it will get circulated through the engine. Anti-freeze is not a good lubricator. Now, 2-3 teaspoons probably is not going to hurt. However, leaks tend to get worse with time. Considering the limited use the tractor gets I would feel safe not addressing the leak right away. But keep a very close eye on it. Your oil will get foamy the more anti-freeze/water that gets into it.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
