Re: Belt pully shaft leaks
Posted by teddy52food on April 07, 2011 at 17:53:00 from (68.169.216.43):
In Reply to: Re: Belt pully shaft leaks posted by CNKS on April 07, 2011 at 17:44:30:
Normally the bolt that holds the pulley on holds the spacer tight too so it has to turn with the shaft . I don't know what kind of set-up you have. After the silicone gets dry the spacer should stay with the shaft & turn indide the seal. Get it clean & dry so it can hold.
