The V-belt pulley has a tapered fitting that fits into the pulley and onto the belt pulley shaft and is pulled tight by its own bolts, so I don't need a bolt in the end of the shaft. The tractor does not have the 2nd belt pulley sleeve/spacer. So, the shaft turning inside the sleeve is the problem. I will try what you say and see if I can get them to turn together. If I had the sleeve and used it to make the other spacer turn with the shaft oil can still leak between the sleeve and the shaft. Thanks for the help.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
