Re: Belt pully shaft leaks
Posted by Janicholson on April 08, 2011 at 06:41:45 from (199.17.6.77):
In Reply to: Belt pully shaft leaks posted by CNKS on April 07, 2011 at 07:41:21:
If you chucked the sleeve in a lathe and cut a groove in the inside for an Oring that fit the shaft, it would make it permanent. Jim
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
