Belt pully shaft leaks
Posted by CNKS on April 07, 2011 at 07:41:21 from (216.144.104.128):
This has been asked before, but I don't remember the answer. On the Super A and others with the same belt pulley, the shaft seal rides on a spacer. The shaft turns inside the spacer and oil leaks between the spacer and the shaft. Is there a fix for that? The only use for the SA is a Woods belly mower, might not be a problem if the belt pulley/PTO is not used. The parts book also lists a "spacer, belt pulley". Since mine has a Woods pulley I don't have that one. Do I need it and does it have anything to do with the leak -- don't think it does.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
