new voltage regulator
Posted by oldiron29 on April 08, 2011 at 14:28:39 from (69.112.87.249):
My farmall C was not charging. Did my trouble shooting and found bad VR. Installed new VR, started and ran tractor charging now. strang thing is when I shut down amp gauge needle goes all the way over to discharge full. Like there is a short. Switch on or off same thing. If I crank the starter some the needle comes back to middle 0 or if I remove battery cable it goes back to middle 0. Where should I look gen. or wiring? any help would be appreciated. oldiron29
