Super a oil pump
Posted by Goodman on April 08, 2011 at 18:07:56 from (166.137.14.204):
Inspecting oil pump noticed issue with bottom plate held on with 4 bolts. The one the gears run against. It seems worped between bolts on two sides. Enough that gasket will not seal. Gears and all are in good shape.
Is this common?
Is there so much pressure to actually bend this plate ?
I'm afraid to attempt to straighten. Looks like some type of cast.
Also, what thickness gasket goes here?
Thanks guys for all your insight.
