The little pump you mention is up by the distributor/mag? It sounds like it is which would mean you do have live hydraulics. That also means you need to use hydraulic fluid...any universal will do. I usually use HyTran since I always have some around. Sounds like you are using the bally pump housing as a reserbior which holds 6 quarts (maybe 7 or 8 if the guts are removed which they probably are). The packing inside your cap is supposed to be there, you can pull it out and clean with kerosene if wanted.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
