Re: A with duals?
Posted by WellWorn on April 10, 2011 at 19:41:53 from (69.95.18.244):
In Reply to: A with duals? posted by WellWorn on April 10, 2011 at 16:37:06:
I was thinking the pressed steel wheels might work for the rears, just wasn't sure if they would mount back to back. Thanks for the confirmation. I'm thinking like AG suggested, the allthread and nutting one up would be easier than trying to line up bolt holes with tires that in all likelihood won't be the exact same diameter.
Still, the fronts were cutting in pretty good, and it was obviously adding considerably to the drag. Did IH (or anyone else) have something wider available that would mount to the existing 3-spoke/clamp fronts? Or do I need to have my local machine shop build a set that would handle something like a 9.5L-15? It would probably be overkill, but then again, extra float beats cutting up the pastures.
Besides, what would a picture of it be worth? :D
