Bolster bushings
Posted by Tom A. on July 26, 2000 at 18:12:09 from (208.241.20.10):
Just finished replacing front bolster bushings on my "H" with catastrophic results. After installing the upper, proceeded to install the lower, but wouldn't go. Then took the pivot shaft and stuck up through the assembly, thinking the lands on the pivot shaft would serve to drive it up with assistance of a hydraulic jack under it. Unfortunately, tractor began lifting up off the cribbing supporting front end. Upper bushing was ruined by the keyways on top of pivot shaft. Lower bushing seized and had to cut it out. Now I have it all over to do again. Would lubricating the new bushings be helpful, or dry ice to shrink them be an advantage. Any you old timers got a solution for me?
Tom A.
Post A Followup
: Re: Bolster bushings
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
