Re: worm gear destroyed the cap? What now?
Posted by mkirsch on April 11, 2011 at 05:12:50 from (64.80.110.74):
In Reply to: worm gear destroyed the cap? What now? posted by Cliff Grosberg on April 10, 2011 at 18:08:21:
There are no locking collars to hold the steering shaft like that.
There is a bearing mounted on the front end of the steering shaft, and the cap holds that bearing in place. Nothing should be grinding on that cap.
It sounds like that bearing has failed. Either siezed or completely collapsed.
How much of the plug is actually left? Does any of it protrude from the front of the gearbox?
Perhaps you can drive it around in a circle using a hammer and cold chisel. All you need to do is get it moving. It's a tapered thread and will spin out as soon as it loosens.
