Re: worm gear destroyed the cap? What now?
Posted by rustyfarmall on April 11, 2011 at 08:32:50 from (209.152.78.140):
In Reply to: worm gear destroyed the cap? What now? posted by mkirsch on April 11, 2011 at 05:12:50:
Exactly!! There is supposed to be a ball bearing on the very end of the shaft, just ahead of the worm gear. That big pipe plug holds the bearing in place. New plugs are readily available, as are the bearings. The bearing is a #6205 size. If you use your tractor a lot, you might want to get the bearing from Case-IH because that one will be rated for the side thrust it is subjected to. If you don't want to spend that much money, and the tractor does not get used a lot, you can substitute a common 6205 bearing for less than $10? Don't quote me on the price as I need to look it up to say for sure.
