Re: 140 Ammeter
Posted by K-Mo on April 11, 2011 at 19:02:23 from (67.55.164.37):
In Reply to: 140 Ammeter posted by Wayne A Johnson on April 11, 2011 at 13:47:12:
If you use an alternator, it will peg the old 6 volt ammeter. It's true current is current whether 6 or 12 volt, but an alternator can put out 40 amps plus. Your old 6 volt generator only put out maybe 10-12 amps at the most. The old standard ammeter on a 6 volt Farmall was probably a 15 or 20 amp.
Short story. If you install an alternator, you may want to install 60 amp ammeter. Or, you could install a voltmeter. A voltmeter provides more information than an ammeter.
K-Mo
