Re: Super C wont turn over
Posted by Albo5000 on April 12, 2011 at 11:08:32 from (76.9.110.206):
In Reply to: Super C wont turn over posted by Ludwig on April 12, 2011 at 10:34:02:
Alright, It does crank, does not start. As for the Carb flooding, when i pull back the air intake hose fuel streams out after cranking. (similar to when my friends H wouldnt start)
When the battery was hooked up to a meter it read 6v, needed a slight charge, and was pulling 597 cold cranking amps when the battery says it will do 625. I think regardless of the battery's charge i will replace the cables with 0 or 00 gauge, it is already grounded (to the positive terminal) on one of the starter bolts and the ground near the driver is dis-connected. I will have to try all the suggestions when it stops raining here.
Thank you all for the advice!
