Re: Super C wont turn over
Posted by Ludwig on April 12, 2011 at 10:34:02 from (63.209.224.64):
In Reply to: Super C wont turn over posted by Albo5000 on April 11, 2011 at 18:56:40:
Crank and turn over are the same thing. I think you mean it turns over but won't start...
A couple pictures would answer a bunch of the questions you're getting...
When it comes to the flooding whats it doing to make you think that? If you've got gas coming back out of the carb you're seeing a very common problem where the need sticks. Take a 3# hammer and tap the side of the carb, see what that gets you.
Take your multi-meter and see what the voltage out of the battery is. A 6v battery should read 7+ volts. If its less theres your slow crank problem.
Its quite possible somebody has run light gauge battery cables, this is pretty common as a lot of people bump start their tractors and the light cables are fine for lights only. The proper cable is the same around than your thumb (0 or 00, I forget), if its sized more like your car its too small...
